Upgrade Time - Evil Style
EvilAlchemist
First off , want to give my thanks to Tigerbiten, BillR, & Kendrak.
Those Guys have been helping me get my Power Supply Questions Answered.
Well, I decided to "upgrade" my Main System so I could run more GPU's
I have 3 HIS 4850 ICEQ running now.
It took me about 2 hours to run the cables and get the system running.
As with any build, cable management is important for air flow and temps
As with my GPU Boxen, I will add a 4th 4850 in a few weeks.
Yes very nice wiring job indeed. Almost too nice, perhaps even so nice that it is Evil.
Nice lookin' "moe sheen" (boxen) Evil :D. It's people like you that are an inspiration to the best DCin' team in the known universe. The mighty [H]orde :p
Folding and WCGing for the CURE
I do my best, but thank you. I still can't believe I have two AMD systems now ...
The world must be coming to an end ..... but I do like their low power draw / low heat quad cores I have now ...
Paid for by the EvilAlchemist commission to elect EvilAlchemist for FOTY for EvilAlchemist
4-HD's, I presume this is not strickly a folding boxen, correct? Damn nice, clean execution.
Sweet Build, I am Jealous. I never seem to have the time....or skills:rolleyes:
To get my boxen looking that pretty. Nice Job.
That kinda makes me want to crack open my P182 and get to re-wiring. I know when I did it a few months ago to restrict less airflow my temps went down on my processor about 8-10 degrees. It still isn't as neat as yours though. Good job.
Very professional job. Looks like you put time and thought into it.
I'm wondering (since I don't recognize) what case is that?
I have found that if your carefull to watch out for long pins on the backside of the motherboard that the 8pin EATX12V wire can be run under the motherboard when mounted with a power supply in the bottom of the case. (just a thought for you).
Clean setup there, sure please those who are neatness-addicts :D
This system is not just for folding, this is my main system in my house.
Looks like a Lian Li PC-A70B...
Yep, that is the case. It is slightly modified with a new top panel that have two 120 mm fans to push even more air into the case. Helps with temps a little.
And keeping your coffee hot longer! :D After all, that IS why that coaster is directly above the case, right?
That coaster is for Rolling Rock or Bud Light only!!!!!!!
The coaster load was at 100% during the re-built and re-wiring of these last two systems.
And Before any one asks, yes that is a Dilbert mouse pad, cause he is awesome.
That is by far the most anal wiring job I’ve ever seen. Yes, that was a compliment;)
