Upgrade Question - 680i
ta7mike
Hi,
I just purchased a Gateway 24" and I experiencing major lag with my rig. Plus, I have already upgraded to Vista Home Premium. Now, I am looking to re-use some of the components, like Case, PSU, etc.
Question: I have purchased a XFX 8800GTS 640 and I am looking to buy the evga 680i, and probably go with either C2D6600 or the Intel 6420/6320 maybe the 4400. Now is it possible to re-use my 2GB DDR2 Ram PC-3200. If not, any quick suggestions on Ram with that board.
Any feedback to the configuration, memory would greatly appreciated.
i would defintaly upgrade the ram as well.. Pc6400 is getting really cheap now a days.
Youm can get a good combo 2 gig for less <$200
If you are building a new hot rod, why use bald tires????
Your 680 platform will perform better with new RAM.......its getting cheaper by the day, now that DDR3 is around the corner.
Thanks for all the suggestions....I presume the current ram would work, but it would not work great. let me see if I can talk to my 'treasurer' to add to my budget :)
Wow Weenis...the ram is only 99.
The evga 680i is the shiznit board of the current age. I have one and I love it.
