Upgrade paths/ideas
So I have been at my new job for two weeks and I am having a blast. Neglected network and servers, they havent had an admin for almost 4 years. Everything that has been done since then has been to keep things operating, and since its a hospital I can understand that.
Which brings me to the question I have, and that is prioritizing. This equipment hasnt been maintained or upgraded for almost 4 years which leaves me with massive amounts of work to do and figuring out where to start and what to start with is a bit daunting.
The core switch is a 4510RE, and they ran 100-200 foot drops from the line cards for servers and end stations on the first floor. Interspersed throughout the entire campus I have found multiple hubs and unmanaged switches daisy-chained together. Sometimes as many as 3 hubs in a row.Their internet connection comes into a 4 port linksys hub then to the ASA, and their Sophos content filter was unplugged, and their firewall has almost 4k lines of config, with 2k of that as crypto maps. Just to give an idea.
I guess I just needed to get some feedback on ideas for coming up with some sort of plan. I have already begun a full inventory, with configs and IOS versions and have begun upgrading those that are 4 or 5 years behind in software. Plans to install top of rack switches to get rid of the cat5e runs that are on the floor from the 4510 to the back of the racks are in the works and so on.
In all honesty, this should be done by someone with more experience but they were unable to hire anyone for 3 years, and then I got the job. After working at my last job I feel pretty confident in my skills just not some of the more advanced things. Nothing like an emergency to make you work harder right? Thanks
You need to talk to the various departments and find out what their biggest gripes about technology are.
What breaks the most, works the slowest, what in IT is negatively affecting patient care.
Then you need to look at what is critical in terms of uptime and data preservation. Any servers with only a single disk? Anything that has no proper backup?
A bunch of hubs might be outdated, but as long as it works, who cares. Same thing with servers; unless it's mission critical and you can't get replacement parts/support, leave it alone for the immediate future.
Once you get the list of those things, then you can look at doing proper wiring, top of rack switches, and replacing hubs.
Finally, they didn't hire someone for 3 years for a reason, probably money. Don't expect them to spend 50K in the next 6 months, unless they've had a change of management who recognizes the issue.
The reason they havent been able to hire anyone is its a little tiny town in the middle of Wyoming. No one wants to live there. They were up front in telling me they have spent zero amounts of their tech budget in the last 4 years and they would give me whatever it takes to get things updated/fixed.
And they also got a new CEO who is younger and a big believer in technology being the future in healthcare.
You are right though, prioritizing to the places that have the biggest issues. I have already sat down with my CIO and talked with him about it. His primary concern is there is no redundancy for anything, and they are running their vsphere cluster is using local disks.
Basically they want things to work. And the way they have things right now its working, but barely. So streamlining some of the network and eliminating some of the things like hubs etc in my mind will help.
Thanks for your input, every bit helps.
