Upgrade or not?
TommyW
I have am 1800+
i want to upgrade to 2600+ barton
to upgrade or not?
Originally posted by TommyW
we dont have it here :(
i also buying a new memory :)
a-data 256x2 ddr500
Why in the world would you be buying DDR500 and especially from Adata?
why not?
its bad comapny?
i want ddr500 for a better overclocking :)
You dont need any more then PC3200 or PC3500 at the most to overclock an Athlon XP. PC3700 and higher has bad timings which hurts performance.
Stick to quality brands like Mushkin, Kingston, and Corsair. You dont want data corruption on your hard drives from errors in your RAM do you?
If your motherboard supports the 2600+, go for it, otherwise its not worth the money to get the new proc and mobo.
i have 8rda3i mobo based on nforce2 ultra400
Go to newegg.com and get a mobile athlon 2400 for $77. Oc it to 2.3-2.5. Great upgrade for a little price. As for the RAM, stick with what the guy above says PC3200-3500 and limit it to Mushkin, Corsair, Crucial, or Kingston. Get a dual pack and use the dual channel option on your board. The mobile is a worthy upgrade because it's multiplier is unlocked and you can get a good stable 25% oc with relative ease...
