Upgrade or no?
Xolos
So, I currently have an XFX HD 4890. Good card and all, plus I got a great deal on it ;) Paid like $120 when they were still floating around $200. Anyway, the issue isn't necessarily the performance as it still plays games well with a bit of eye candy on. Granted not too much or the FPS dips too much (I'm looking at you AA). I'm a slight stickler for keeping good frame rates and such. But really as long as I don't notice the slow down it doesn't bother me too much.
So, the real question is should I upgrade or just skip and wait for the next generation of cards. The only thing that is really wrong with the card per se is I believe the fan is slowly dying. Plus, it gets a bit louder under load than I'd like.
I guess the "requirements" I'd for a new card are:
1) Has to perform well. Not hard seeing the raw amount of power even $150 or so gets you now.
2) Quiet/ near silent on idle, but some noise under load is fine. For reference I have a little NZXT Vulcan with 3x Nexus 120mms, 1x Nexus 92mm, and a Gelid PWM fan for my CPU Cooler (Coolermaster Hyper 212+) and I can hear it, but it doesn't bother me. But I can turn down all the fans and hear the GPU only.
3) Price: under $400. I know that will pretty much buy any single GPU out there minus a couple. But frankly price really isn't an issue with the GPU to me. However, the less I have to spend is of course better. I'm not made of money.
Any thoughts? Thanks in advance!
P.S. - I won't be purchasing it this month. Seeing as new cards just came out, I figure there will be a slight lag with new cards. I'm thinking at least 3 months here. So, I'm looking at Jan or Feb for a new card.
Next gen cards are here. It'll be a while until the next refresh. If you want the more mature stuff, it seems like this release is the V2 release of the past releases for both ATI and Nvidia, though Caymen is actually a "new" architecture (I think, don't quote me on that)
I love Arctic Cooling's heatsinks. They're dead quiet and cool amazingly well. If I were you I'd get either a 570, or wait for a 560 if you wanted a bit lower price, and then put an AC Accelero on there.
Oh, screen res is currently 1680x1050. However, I've been looking to upgrade my monitors for quite some time to 1920x1200 or 1920x1080.
