My father-in-law dropped his tower off to me last night so that I could fix it. He was complaining of excessive load times on web pages and the occasional "Virtual memory is low". So, I have been working on it and managed to get things running fairly smoothly. I disabled McAffee and a few other start ups. I have run SpyBot, Super AntiSpyware, AdAware, and HiJackThis. The system appears to be clean. I ran CCleaner to clean out the junk and that deleted about 1 GB of crap. I also bumped up the max page file to 1152. So all in all, it is running fairly smoothly.
The system is fairly old, built in Dec. '03. It is an AMD Athlon XP-2000, MSI K7N2GML mobo, 256 MB DDR PC3500, 40GB HD, and WinXP Home. It is only used for email and the web, NOTHING ELSE. I was going to tell him that he should put some RAM in it. The mobo will take 2GB. 2GB of DDR is right around $50 delivered. So then I got to thinking that maybe for a little more money, a new bare bones kit might be the way to go.
Given that the system will never be used for anything buy web and email, what would you do? Try to make the existing configuration work to is full potential? Put in some RAM? Or, recommend a new inexpensive system?
