Looking to upgrade my system. its a C2D runnin at 3.4g w/ a 8800gts512
Want the most bang for the buck...if the weakest link is the vid card and ram....or replace the core of the system..dunno..been out of the mix for a while now. I could do vid card now and get by until I can afford the rest if swapping the card will work.Thought getting 4mb ram(8 total) and fastest card avail would be my best bet but who knows.
1) What will you be doing with this PC? Gaming? Photoshop? Gaming mostly
2) What's your budget? Are tax and shipping included? $600 total
3) Which country do you live in? US Ohio
4) What exact parts do you need for that budget? Video card and ram if keeping rest of system or vid card, ram, mb, cpu if replacing major parts
5) If reusing any parts, what parts will you be reusing? Corsair hx620, HD's, dvd, case, sb xfi (the cpu is a c2d 6850 at 3.4g, Abit ip35pro, 4gig ram(ddr2) and a 8800 gts 512...I have Win7 as well but dont know what part of the pc it is linked to...the mac or what)Keeping kb mouse and case as well..
6) Will you be overclocking? lil bit
7) What is the max resolution of your monitor? What size is it? 1920x1080 23"
8) When do you plan on building/buying the PC? <2wks unless new stuff is right around the corner???
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc. Stable and fast...fast hard drive support would be nice if I upgrade my HD's
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit?I own retail win 7 64bit if it transfers with a new pc...??
Thanks a ton in advance
