Executioner
- Apr 22, 2015
Here is the latest prompt by MS: Upgrade now" or "Upgrade tonight."
http://www.businessinsider.com/microsoft-is-forcing-windows-10-upgrades-2015-12
I'm so glad I turned off updates to avoid this harassment. This is getting rather annoying now. If you've been blocking the Win10 upgrade using the GWX Control Panel, make sure you've installed the latest version as it installs a service that prevents the Win10 installer from re-installing itself: http://ultimateoutsider.com/downloads/
