Upgrade help?
Scocho
I’m going to a MicroCenter for the first time. With my current build listed below, are there any recommendations on what to upgrade if I’m trying to keep it under $200?
GPU: AMD Radeon rx 580 2048sp
CPU: AMD ryzen 5 3600
RAM: 16 gb DDR4-3200
Mobo: ASRock a320M/ac
Without knowing anything about what you are doing.. assuming games - Spend more and get a 5700X3D
get a gpu, stretch a bit if you have too. just make sure its x16 not x8, since youre limited to pcie 3.
