Upgrade help!
onpragu
Hey guys I'm new.
I'm getting an X2 4800+ toledo and just bought an evga 7900GT.
I was thinking about getting the following parts:
coolermaster centurion http://www.newegg.com/Product/Product.asp?Item=N82E16811119068 - I'm a little worried it wont give me the cooling i'll want/need but the price makes it very preferrable to a 150 dollar case.
1GB stick of mushkin 2-3-2 memory http://www.newegg.com/Product/Product.asp?Item=N82E16820146424 - This ram seems to have good timings and is not much more expensive than any other gig sticks. i plan to buy one and get another in a few months or so when I get more money. *i'm not sure it will be compatible with my motherboard*
ASUS A8n sli mobo http://www.newegg.com/Product/Product.asp?Item=N82E16813131524 - on newegg many people complain that this motherboard has problems such as primary sli x16 slot being faulty. *additionally don't know if the ram will be compatible*
antec smartpower 2.0 psu http://www.newegg.com/Product/Product.asp?Item=N82E16817103937 - PSU - i want this to be able to cover pretty much 1-2 harddrives, maybe 2 sli vid cards, and other basic stuff that will be in there including fans, cd rom drives etc.
any help would be appreciated and if any of you know any parts i should get instead of these any help would be great.
i have had 3 sets of ram on my current board. with no issues at all. started with crucial value ram 1gb, then upgraded to kingston 1gb, and then settled down with my OCZ set.
the asus a8n sli is a fine board.ive recently built 3 systems with that board and all worked superbly.2 were oclocked and 1 was stock speeds.the a8n series of asus boards is probubly the best ones out.bios is mature,layout is good and they are stable boards.out of about 20 systems i have built in the last year using the asus a8n series boards none have failed.i had 1 DOA board and newegg exchanged it out and 3 days later i had a new board.the ram you have will work fine in the a8n sli board.
