Upgrade help please!
Sock Troll
Gaming, mostly Planetside 2 and BF 3, a bit of Skyrim here and there.
$450, maybe $500 if I promise to buy her a shiny at the next ren fair.
Palestine, Texas
4) What exact parts do you need for that budget?
CPU, ram, mobo, possibly a cpu cooler if it fits the budget.
5) If reusing any parts, what parts will you be reusing?
Antec Earthwatts 80 Plus Bronze 600w PSU, 6850 I don't remember the brand of, SSD, HDD, and DVD drive all in an Antec 300 case.
6) Will you be overclocking?
Most certainly!
1920x1080P, 23"
Tuesday afternoon, as I will be in Houston near a Microcenter.
9) What features do you need in a motherboard?
A handful of USB ports, Xfire/sli capable, decent overclocker. Onboard sound, doesn't need to be fancy.
Win 8 64 bit.
I'm updating a frankenbox that began life as a Gateway! Swapped out the case, psu and vid card to those mentioned above, now I'm looking to alleviate some my CPU bottleneck for PS2.
Right now I have a Q8200 @ 2.3 ghz on an oem nForce 730 mobo, so I can't even try overcloking it. I know for most games I would be better off updating graphics card, but the only time I am ever GPU limited in PS 2, I'm dead and getting high 50ish fps. Alive and in large battles, I hover around 10-15.
I'm currently looking at an i5 3570k, gigabyte ud5h, and whatever 8 GB ram kit is cheapest, as well a cooler so I can start overclocking. Alternatively, I could spring for a 3770k and go with a slightly cheaper mobo in what is likely a vain attempt to stay relevant if/when we see more games using more than 4 cores.
Any and all advice and thoughts welcome, thanks in advance!
Edit: Looks like they have a MaxV Gene open box for $164.... if it's there and nothing's missing, I should nab this, yes?
Is that DVD burner SATA?
And no you don't need a 3770K. Your budget is enough for a new GPU if you're willing to go for that $500 budget.
Yes, the DVD burner is SATA., though it's not actually hooked up right now, as my cat ate my other SATA cable, so I suppose it's not technically necessary, just nice to have those few times I need it. Getting the i5, an asrock extreme 4, and a $50 ram kit leaves me ~$160 from a $500 budget. Would it be worth upgrading my gpu to the 7770s and 650s I see in that price range?
I was originally planning to nab a new gfx card later this year, maybe black friday if a good sale hits and the money gods have been kind. Probably should have said that in the OP.
asus P8Z78-V LK i5 3570k a cooler such as hyper 212+ 8gb ddr3 1600 8,8,8 1.5v Gskill NCIX has these for $51 right now. I would stay away from Asrock with a 10ft pole, alot of my freinds have gotten them over the last 2 years and few are happy with them, most having rma them to go with MSI or Asus for various performance issues and manufacturing flaws.
while 6850 is a bit underpowered I think you are hitting a cpu bottleneck more then anything else, you can clock the 6850 up some for sure, but, its not the gpu being held back, pop in a good cpu in a good motherboard and you will see a heck of a good difference.
Gaming specifically, no point in going 3770, 3570 is more then powerfull enough(few if any games show the benefit of the $100 or so more 3770 unless you are using multiple gpu and even then) 3570k clocks up very well with a good cooler, hyper 212+ is a very good cooler for its cost ~$30 online. Pair it up with a good Asus, MSI, some gigabyte boards and it will really fly, couple with 1600 class low latency ram 9,9,9 or 8,8,8 type timings and youre laughing (Gskill, and Corsair are 2 great examples)
That's what I suspected, and to be honest I wasn't looking forward to down grading to the asrock , a few reviews I've read made it seem a little underwhelming. Anyways, I'm about to hit the road, I'll buy it, build it, and report back in a few days. Many thanks guys!
