Upgrade Help needed...Please read !!
shkj
Hi All,
I was just wondering, I am in the proceess of upgrading my current machine ....The machine I have now is
An Asus socket 939 motherboard (A8V Deluxe)AGP,AMD64 3200+(VENICE CORE),and 2 Gigs of DDR400 low latency RAM with timings of 2-3-2-5 (Patriot PDC2G3200LLK 2GB Kit DDR400 PC3200 Dual Channel Memory (2) 1 GIG sticks
My operating system/application boot drive is a 74 gig Raptor with Win XP Pro W/SP2
My storage is (2) Hitachi Deskstar T7K250 250GB Serial ATA II 7200RPM Hard Drive w/8MB Buffer configured in RAID 1
for protection and also backed up to an external firewire drive as well
I am looking into upgrading my current system to be used primary for digital photography (Photoshop), and running general apps Please keep in mind I DO NOT Play any games at all
The Photoshop scratch disk is a 7200RPM 8MEG Cache SATA drive all by it's self
I am currently using a GeForce 6800 xT with Dual DVI's attached to a Dell UltraSharp 24075FPW Widescreen and a Planar 20" widescreen and calibrated using Gregtag Macbeth Eye-One 2
HERE IS MY DILEMMA:
wHICH CPU Should I upgrade to ???
Dual Core AMD 4800+ (2.4GHZ 2x 1 MB L2 Cache) $300
Dual Core AMD 4600+ (2.4GHZ 2x 512KB L2 Cache) $249
Dual Core Opteron 180 Denmark 2.4GHz 2 x 1MB L2 Cache $300
Dual core Opteron 185 Denmark 2.6GHz 2 x 1MB L2 Cache $412
(Does Photoshop make use of the extra Cache on the processor 1 MEG vs.512) ???
wHAT IS THE REAL DIFERENCE BETWEEN THE x2 AND THE OPTERON ??
kEEP IN MIND THAT THE A8V is absolutly horrible at overclocking nor do I have any interest in doing so at this point in time !!!
I just want speed and most important stability !!!
Any suggestons would be most appreciated...Thanks in advance...shkj
well i whould put my money on the opterons, but you really should look for one with toledo core they overclock way better. and allso i whould recomend that you get a 165 or 170 they have know to overclock much better than the 180 and 185 line of chips
btw i had that same asus mobo that you curently have and i really have to say that i fell your pain, it sucked big time you really should grap your self a more capaple board.
