ellover009
- Jul 17, 2005
Right now i'm running
2.8 p4 HT 800mhz bus
120gb seagate HD
Asus P4P800Deluxe mobo
Sound Blaster Extigy 2
logitech mx1000
antec 430 power supply
Geforce 4 ti4200
Guetto 17in HP monitor
512 ram
2 Options I built my pc at start of last year before pci spress caught on.
option 1 upgrade video card and add ram
option 2 overhaul and remake pc with pci express, add anthlon 64 x-2 and a 7800gtx
So far I like option one because it is more economical and 2.8 ghz isn't necesarily slow, my mobo can overclock to 3.2 with no issues.
cards I have found
$350 for a x850xt at www.compusa.com
$250 for a x800xl at comp usa
$206 for a Refurbished X800XT PE at www.ati.com with 1010 code 10% off.
My thoughts the x800xt pe from ati is a sweet deal but I dunno if i can trust refurbished cound mean a) trade in program b) it was broken then fixed.
I would like Nvidia 6800 because of shader 3.0 but they require more juice, it gets stepped on by the x850xt speed wise, and graphical quality is not as nice unless game supports sm3.0,
Companies are starting to discriminate Splinter Cell pandora tomorrow runs shaded 1.1 or 3.0 meaning theres no shader 2,0 wich ati supports and 1.1 is crippled a lot. theres also some issues with the game running it on 1.1 some pixels.
Far Cry has added some extra features on 3.0 better texture, bonus if u running windows 64 bit.
Games are gonna shift to shader 3.0 exp UT 2006, STALKER, ect.
New ati is gonna be sweet R520 but they been so occupied with xbox 360 chip they delayed to the pc market, theres also rummors that they encountered some issues with 32 pipes, that they might need to scale down to 24 or 20. Or they could have issues getting Shader 3.0 to work properly
Intel VS AMD. AMD has nice processors, they need less juice, can hawl more, 64 bit, and AMD for some reason seems to work perfectly paired with SLI. Intel SLI is an insult. Only downfall of AMD is that all AMD mobo only support DDR memory, Intel has DD2 memory. DDR 2 runs cooler can clock faster. Intel is nice ddr2 rocks it but bad SLI.
Future is soon and if ppl will upgrade I recomment the Anthlon 64-x2 series, dual core processor means you can multitask without a hitch. Pair this with a 7800gtx u got a nice ride.
Gotta give credit to Nvidia 7800GTX, they finally made a card that can match immage quality with ATI, and can out run 2x 6800 ultras on SLI and a x850xt while runnings higher antilassing ect. Not bad deal spend $100 extra on a card that will actually dowble performance. and hdtv
if ur on the cheap side a amd 64 3600-3800 should provide adequate performance can be found at $300 or as low as $150.
My final thoughts: No matter what u get something new will come out withing 2-3 months and ur technology will become obsolete. Lesson take what u get and be happy with it.
AMD VS INTEL
http://www.tomshardware.com/cpu/20050714/index.html
Splinter cell discriminates shader 2.0
http://techreport.com/etc/2004q3/crytek/index.x?pg=1
7800gtx smokes all other cards even 6800sli
http://techreport.com/reviews/2005q2/geforce-7800gtx/index.x?pg=1
wich brand better 7800gtx
http://techreport.com/reviews/2005q3/7800gtx-comparo/index.x?pg=1
Please post ur thoughts and ur recommendations.
120gb seagate HD
logitech mx1000
Geforce 4 ti4200
512 ram
cards I have found
AMD VS INTEL
