Upgrade from a 6600GT to...?
MiG29TangentBoy
OK, my wife is going to want to steal Oblivion from me when she's done with stealing my Morrowind disk. Currently she has a 6600GT AGP, which is fine for that game. But Oblivion needs a bit more horsepower. So, better choice for an upgrade: 6800GT or 7600GT? 6800GT seems better on paper (256 vs 128 bit memory bus, higher bandwidth and more pixel pipelines), but 7600GT has more recent features, higher fill rate and is clocked higher. Replacement will be PCI-e for her Asrock dual board, which takes both. Trying to keep it under 200 bucks, too. So, what would you choose, between the two?
Comments as always are welcomed! :D
PCI express or AGP? For 218 after rebate, you can go to newegg and buy a new sapphire X1800XT. if you want to spend less, the 7600GT sounds pretty good. better than a 6800GS and the 6800GT.
I can run Oblivion just fine at a nice resolution with a single 6800gt. Theyre pretty cheap on eBay too, if youre looking at a money crunch.
I would go with the 7600gt.. PLENTY of power and all the newer features. PLUS 6800gt's are starting to crap out.. you usually see a few threads a day about how they are dieing.
7600gt
