upgrade from 20" to 24"
CoolGuy90
About a week ago I bought a Dell 2007WFP. It is a fantastic monitor, however I think I may want a 24" montior so I can get 1080p on my 360 and overall bigger screen for movies and games. I was looking at the 2407WFP but since the HC has many problems and I can't find the older model A04 anywhere, I have been looking at other brands.
Bascially, I need a 24" monitor that has both VGA and DVI input, and the ability to toggle between them.
Any suggestions?
i had the same problem with you i want to upgrade to 24" from 2007 and i dont know which panel its ok...also i dont know if these ghosting issues for 2407 remain unsolved
I think the ghosting issues only affected the HC version of the 2407WFP. I've been reading up on the Benq FP241W and it looks like a good 24".
