I am wanting a to upgrade my computer to play Modern Warfare 2 multiplayer. I am reusing my case, keyboard, mouse, os (windows 7), DVD (IDE), HDD (IDE), monitor, headset. I am using a Ultra X-connect 500watt psu (+5V@30A, +12V@34A, +3.3V@28A, -5V@0.3A, -12V@0.8A, +5VSB@2A) and would like to reuse that if possible.
I will be playing at 1680*1050
What do you think of this build?
AMD Athlon II X3 435 Rana 2.9GHz 3 x 512KB L2 Cache Socket AM3 95W Triple-Core CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103724
ASRock M3A770DE AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
OCZ Gold Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227346
POWERCOLOR AX5770 1GBD5-PPG Radeon HD 5770 1GB 128-bit GDDR5 PCI Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131327
LOGISYS AD01 20-pin Male To 24-pin Female Power Adapter Cable
http://www.newegg.com/Product/Produ..._pin_to_24_pin_adapter-_-12-887-007-_-Product
COOLER MASTER SAF-B83-E1 80mm Case Fan - (I had one case fan go out on my CM Stacker case)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999070
How easy would this be to OC and how high could I easily and safely go if I added something like this:
XIGMATEK HDT-SD964 92mm Rifle CPU Cooler
http://www.newegg.com/Product/Produ..._re=Xigmatek_HDT-SD964-_-35-233-014-_-Product
