Setzer777
- Sep 9, 2005
So, I'm taking advantage of eVGA's step-up program and trading in my 7800GS AGP for a 7900GT PCI-E card. In order to be able to use my new card I'm going to have to replace the motherboard and cpu I'm using currently. I was almost ready to buy an AMD 4400 x2 with a DFI LP Ultra-D motherboard when I came across the Core 2 duo chips by intel. After doing some research it seems to be a better choice over the X2 cpu and the price is about the same(board and chip) as I was going to pay for the AMD 4400 x2 and DFI board. My only problem is the memory. If I go with the AMD cpu and board I can simply transfer my 2gb of pc3200 to the new board but if I go with Intel then I'm going to have to pay $250-$300 more for 2gb of pc6400 memory, which I wasn't really too excited about. I just want to know from you all if I should wait and save up and go Intel with new memory or just go with AMD? Will I notice that much difference? Thanks for your input!
