jgarcia408
- Aug 8, 2004
Im going to be upgrading my PC and need some help. For the past 5-6 years I have used AMD as my processor. I think I may be ready to change that. Im starting my research of what my next PC will be. My friend recommended I come here to get some answers to some questions, so here I am, and here are the questions.
First question: What is the better way to go? AMD 64 or Pentium 4 Processors. I get one group saying go P4 (that group is of Intel loyalist), and another saying go AMD 64 (and that group is of AMD loyalist). Obviously those two groups are a little bias. Then I ask groups that dont seem to be particularly loyal to either and I get mixed recommendations. Im really interested in Intel because of Hyperthreading, but I dont know if its something I really need. So, what should be better?
Second question: What Mobo do you think is the best, based on your answer of the first question? I have been looking at the DIF Lanparty Boards and they look really good. I also like MSI boards though. I have heard ASUS is really reliable too. I dont OC, although I might try to on this board, so that should be taken into consideration. I have never OCd a processor before, so I would like a board that is user friendly for OCing. I use my PC for Gaming (main use), Video Editing, Photo Editing, and other basics like internet, email and word processing. So, referring to any boards, not only the brands listed, which do you think is the best?
Third, and final question: PCI Express, should I take that into consideration. This upgrade will probably be the last Mobo/CPU upgrade I make for a while. The only other upgrades would be Memory and Video Cards. So, I have been hearing about PCI Express, is this something that I should look for on a new Mobo, or is that something that I shouldnt be too concerned about?
The components like Video Card, Hard Drive, Optical Drives, Firewire card, and possibly memory will be transfered from the PC I have now, to the new one. If it helps, this is what my current PC has in it now.
Motherboard: BIOSTAR M7NCG 400
CPU: AMD Athlon XP 2400+
Video Card: ATI Radeon 9700 Pro 128MB
Memory: 512MB DDR PC2700 (2x256mb) (dont know the brand, but thinking about upgrading to Crucial 512MB PC3200)
Hard Drive: Maxtor 80GB 7200rpm
Optical Drive: I/O Magic 8x Dual Format DVD Burner
PCI Cards: Dynex 3 Port Firewire Card
Thanks in advance for any information given.
