Hi,
Here are my current system specs:
AMD 2000+ XP CPU
MSI KT3 Ultra2 Motherboard
512 MB PC 2700 System Memory
80 Gig Seagate 7200 RPM HD
40 Gig Maxtor 7200 RMP HD
128 MB GeForce4 TI4200 Vid Card
350 Watt Enermax Power Supply
Anything else?
Thinking of dropping in an AMD 3000+ (Barton Core) 333 FSB CPU (Motherboard supports it) and another 512MB PC 2700 of system memory. The CPU runs at around $100 and the mem around $75. Would the performance gain be worth the money? Or should I hold off?
I don't do hard core gaming. Sometimes play RTCW once in a while. I use the system mostly for web developing. But I would like to play FarCry and Unreal Tourney 2004. I should probably upgrade the video card too huh? Like I mentioned, I mainly use the pc for web developing. I will have Dreamweaver MX 2004, Photoshop CS, Illustrator 10 as well as 3 different browsers for testing purposes open all at once, so I figured that the extra 512mb would be a good idea.
Thanks!
AMD 2000+ XP CPU
Anything else?
Thanks!
