Updating video card
monoho
I have a GeForce gt 430 from pny with 1 gig memory, it has served me well but it's old and starting to over heat frequently and I don't feel like hassling with the thermal paste. I am not a big computer gamer I am fine as long as a game runs even on bare minimal settings. So I was wondering If I could get by with just upgrading to the gt 600 series since there about $60 or $70 now. Will that make much of a difference?
SYSTEM INFORMATION
Computer Manufacturer ASUSTeK Computer INC.
Computer Model P8Z68-V PRO GEN3
Operating System (O/S) Microsoft Windows 7 Ultimate Edition Service Pack 1
Operating System Build (O/S) (build 7601), 64-bit
Operating System (version) 6.1.7601
System RAM 8.1 GB
CD or DVD Device HP DVD Writer 1070r ATA Device
System Hard Drive Overview
System Total Storage Size: 614.7 GB
MOTHERBOARD INFORMATION
AA Number not detected
BIOS Vendor American Megatrends Inc.
BIOS Version American Megatrends Inc. 0402
BIOS Release Date 0 2/05/10
System Memory 8.1 GB
Built-in Audio Driver Component not detected
Built-in Audio Driver Version 6.1.7601.17514
PROCESSOR INFORMATION
Manufacturer Intel
Model Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
CPU Speed 3.1 GHz
Link to Processor Specification Link to Processor Specification
Any card recommendations would be appreciated! Thanks!
750 just came out, might be worth looking into, first Maxwells.
I'd recommend a GTX 750 1GB, too. They're just a little more expensive than a 650 but have up to 1.5x the performance. You may also want to grab one sooner than later before the mining inflation gets too bad.
I Really don't want to go over 100 dollars, my gt 430 ran crysis 2 and far cry 3 alright on low settings. Also are you saying there is a gt 750 or a gtx750 cause all I can find are gtx 750 they are all $130 dollars.
If you can wait a few weeks, the AMD 675 comes out, which should lead to price drops. Which might get you more bang for your $100.
I think the motherboard I have is made to work better with nvidia cards, never used a Radeon card before unless a stock comp I had came with one I didn't know.
Nah, it won't make any difference. nVidia doesn't have anything at that price point that is even close to the 7770.
