updating Sata Controller Bios
Yakyb
i have bought 2 Sil 3114 Based PCI Sata controllers
they hang on boot with a 750 Gig drive attached.
looking at some other threads i have found it appears that a simple bios update should fix them so i went to
Sil Bios Page
and got the SiFlashtool and 5403 bios
went into command prompt
and used command
SiFlashtool /BusNum:01 /DevNum:09 /File:5403.bin
(bus 01 and dev 09 obtained from device manager)
and press enter nothing happens
i then used the command
SiFlashtool /v
to see all listed controllers
interestingly it only reports the onboard sil3112 controller
anyone have any ideas
that just makes it say
'no silicon image storage controllers were detected'
dispite device manager saying there are 2
had similar issues with both biosflashers from sil-img webpage
it requires some device connected via controller to flash the sucker, but in reality when device is connected i cant flash bios, it just refuses to do so, or isnt able to do so, but when i disconnect device, it refuses to see controller and result is the same - no cigar :mad:
sorted it now thanks to FreeDOS
download the image of free dos
add the binaries (.bin) to the image along with UPDFLASH
burn image
load live cd
navigate to x:\bios (location of the bios on Live CD)
run updflash b5403.bin (then your device name read the readme that came with updflash)
enjoy
this is what i needed to do in order to set the sataraid controllers as plain sata controllers
and allowing over 500GB drives
