Updating nForce Drivers
TechLarry
RIP [H] Brother - June 1, 2022
When you guys update nVidia nForce drivers, do you just install over the old one's ?
-Larry
I format :D Chipset drivers are important to have a clean install, but just do what nVidia recommends.
i like to uninstall the old ones, and i never do the ide drivers, seems to cause a problem with somethings.
well, if you feel you need to update.....
I first go to add/remove and remove JUST the chipset or sub-portion.....this would be if you have nVidia for more than the MB.
Safe mode and run Driver cleaner a couple of times.
Restart and install the new drivers.
my recommendation is NOT to...if it aint broke then dont fix it...theres no real performance improvement...most likely will result in more problems than benefits
I just spent 13 hours (until 3am) building, setting up and imaging this new machine.
I'll be damned if I'm formatting :)
-Larry
