updating intel drivers in Optimus
zalazin
Asus in Wireless Widi won't run bencmarks or games full sreen. But my Hp i7 laptop will.
Asus is N550JK I7 Optimus GTX 850m/Intell4600
HP is I7 Optimus 740GT/Intel4600.
Both have the latest Nvidia driver. The only difference I see that the Asus Intel display driver is over a year old. It doesn't update with windows update or Intel utility. Says it is an custom OEM driver. I couldn't find anything on Asus site. I downloaded the standard Intel driver but can I just install it? I don't want to screw up the machine. Thanks for any info...
The motherboard BIOS will also contain the video BIOS and have a fair amount of control over how it operates. You might also check for updates to this as well as the driver.
figured it out extract the intel drivers with winrar, then update using the browse for driver have disk, select new inf64 file worked perfectly now have dx11 games on screen and benchmarks run okay. Ps let the audio stuff install too it is automatic, Then restart
