Updating creative XF-I drivers?
newls1
I've done a fresh format, and am now going to install my XF-I drivers, bnut my question here is: I downloaded the lastest driver from there site just now, do I go ahead and install just that, or do I still go through with the driver that came on the CD, and THEN upgrade using the "auto Update" web feature? Thanks
If you want all the extra software and tools(or to pick and choose the ones you want) I'd do the CD first followed by Web Update.
I found with my extreame music that if i did it that route then the control panel would not recognize the card, so i way i did it was.
1) Install updated audio driver from crative website.
2) Install CD software but did custome and unchecked Audio Driver
Seems to work for me just fine.
When I purchased the XTremeMusic last month, I found no need to install the CD: Simply install the latest drivers from the web site, and that includes the Audio Console. I can't figure out what else anyone would need.
You don't get the adjustments and programs if you do that.
All you need is the driver from the website. It comes with the mode changer utility where you can adjust all the soundcard settings. The software that Creative puts on the CD is crap. Reminds me of AOL invading your system with all kinds of bloatware, spyware, adware, etc.
