I recently bought a laptop with an ATI Mobility Radeon 9200 card. It has a 3.06 GHz processor and 512 MB ram so I assumed it would be able to support some decent graphics capabilities. As a test, I tried running Doom 3. The game would not allow me to run it in anything above 640x480 with the lowest quality settings. When I tried to run higher settings, it just automatically changed them back down. The graphics quality at 640x480 was so bad that it looked like a different game. My PC is only 2.4 GHz with 512 MB ram, running a 64MB GeForce 4 Ti4200 which is several years old...and I am able to play Doom3 at the highest settings on the highest resolution. On the same resolution as my laptop, with all the same settings, it also looks superbly better. So somethign is definitely not right.
It was suggested to me that I install the latest Catalyst drivers with this tool:
http://www.driverheaven.net/patje/
However, running the tool requires pointing it to some ATI folder...which did not exist on my machine. There was an "ATI Technologies" folder which contained many files, some of them having ATI icons, but none of them executable...and pointing to this folder didn't satisfy the Catalyst program.
I don't know what that program was but it didn't seem to be official ATI stuff, so I decided to go to ATI's website and try to update my driver software from there. When I ran the ATI driver update program, it said "appropriate hardware or software not found." Interesting....after reading through the help file, it said that all previous versions must be uninstalled in order to update (sounds kind of ridiculous). So I assumed that I had a previous version installed that I neeed to uninstall first.
So I went to add/remove programs and got rid of the 2 things that had ATI in the name...I think they were ATI Display Driver and ATI Console. Of course after uninstalling these the hardware was not being detected at all. I restarded my machine, and tried to run the ATI driver update software again...once again it says "unable to locate required hardware or software." !
So then I used Window's automatic hardware detection thing....and it was able to load something that detected the driver, although I doubt it is up to date or optimized.
In dxdiag, it says the main driver currently is:
ati2dvag.dll
version: 6.14.0010.6396
Now, I would really appreciate some help figuring out how I am supposed to install the ATI driver and then optimizing it with these silly Catalyst things. Thanks (NVIDIA never gave me any trouble :/)
ati2dvag.dll
