DeathCloud
- Jul 21, 2005
So I just upgraded my cpu block and went ahead and ordered a gpu block as well. The block I bought only cover the chip and not the ram modules. I put the little heatsinks on all but 2 of the modules, do you think leaving heatsinks off the last 2 modules will cause heat issues?
