Wheresatom
- Mar 20, 2007
So yesterday, when I got home from picking my truck up at the mechanic
i went into my bedroom and heard what sounded like a hair dryer coming from my computer. Normally my computer is rather quiet, as I built it to be so.
I took off the side panel and realized there was some extra noise coming from the power supply (Antec Truepower Trio 650W) and at that point decided to stop my SMP, save my girlfriend's homework, and shut down the computer until further checking could be done. I have heard bad things about power supplies in the past.
So I took out the power supply and set it next to the computer and hooked everything up, in a hope to isolate the noise. Long story short, I ended up taking the top off the power supply and setting the fan next to the inner workings and starting everything. The fan was the culprit. It seems to have suddenly gone from not noticeable to noisy as crap.
As of now I feel like the computer is ok to use, but just annoying to listen to. My SMP will have to be off about 50% of the day for sleeping and no one being home, but I should still make deadlines.
Question portion:
Am I correct in assuming everything should be ok, as long as I can put up with fan noise for the time being?
Can I just replace the fan without any problems? I think it might have had a 3 pin connector on it, but I am not entirely familiar with those things, so I may have been wrong.
Would I just be better off getting a new power supply?
If I should just get a new power supply, which one should I go with? I know I want 80+ certified. I would like to be able to eventually get a quad core and OC it, and I want to be able to buy a new video card soon (maybe not AS soon anymore). I was hoping to pick up the 9800GTX+ around when it comes out. What kind of wattage would that need? Would 450 be a good minimum for that kind of setup?
Thanks for everyone's help!
Question portion:
