update needed help
fightingfi
Update AMD Chipset Driver 18.10.20.02 or latest version before update this BIOS.
amd hasnt updated this where can i get it from please its not on the gigabyte site updated either.........tankies in advanced
The latest direct from amd are : 18.10.1810 (yes, that is newer that 18.10.20.02)
As you did not say what motherboard you are installing them on I will direct you to go to their support site and answer the questions for yourself.
just get the gb or the asrock one(either will work) that were already linked in your other thread about this same thing. you only needed one thread and talk like and adult please and THANKS.
