Upcoming Z890... info?
M0710NM4N
Just wondering if anyone can tell me how the motherboard industry typically works, in regards to releasing info on upcoming releases? Z890 are supposed to drop along side the release of Arrow Lake... will those manufacturers release info on that line of boards prior to their release, or will we waiting till the actual release date to find out any real details on them?
And I wonder what design tools do companies like ASUS use to churn out so many different but similar models.
I'm not sure what I want yet aside from a 4x PCI-e slot in the bottom position and as many M.2 plugs as I can get. Memory is going to be interesting this time around. It looks like there will be CAMM2 boards, support for CUDIMMs, and of course we have no idea about gear 1 vs. gear 2 or how Arrow Lake will behave with more than one rank per channel.
Yeah CAMM2 memory sounds very cool. I’d love to get that on my mobo.. shorter traces to the socket and a generally cleaner look. Obviously don’t see that on the z890 carbon..
From singe_101 post url above..
“The MSI Z790 PROJECT ZERO PLUS makes this vision a reality and will be on display at Computex 2024! It supports CAMM2 memory modules ”
Looks like it’ll be on the project zero z890 too
Edit:
View: https://youtu.be/5jDdbEd4zeA?si=LfWbjDYQyuYoYFFl
I'm eyeing that CAMM2 memory as well. I'd like at least 64GB. I have no idea how CUDIMMs are going to behave with more than one per channel, but it sounds like CAMM2 will be better than regular UDIMMs at 64 or 128GB.
I'm not so sure about the project zero setup. I kinda like the idea, but then I'm stuck with project zero cases. That's fine for my next build, but I have this old Lian Li full tower with a row of 5.25" external drive bays down the front that I keep my file server/full time Linux box in and it's likely my next board will end up in that case eventually. Just turn down the power limits so it doesn't overload the mid 2000s cooling setup. It's not that bad though, desktop boards do fine at Intel or AMD defaults. That case originally had a pair of Opteron 270s or 275s in it. Those were around 90W each. I got it from a friend after he retired the Opteron machine. He ran physics simulations on it when he was working on his Ph.D., so it ran flat out overnight or longer. That said I'll buy a Project Zero board and case if it gets me faster memory in the amount I want. Well, unless I decide to go AMD.
When will the Project Zero layout be adopted by ASUS and Gigabyte? Or will they just ignore this development?
It would be ASUS BTF to plug into the back of the motherboard? Gigabyte B650E AORUS STEALTH ICE probably isn't even good but it counts for not ignoring it. They already shipped their Project Stealth DIY PC kit with no PSU installed.
BTF = ???
OK, but why didn't ASUS do BTF features on the new AMD boards? This feature never would have occurred to me, but now that I've seen it I want it for my next motherboard, to improve airflow.
Intel would have to have a significant advantage over AMD to get me to switch. Yeah I have become almost an AMD fanboy. Call me an AMD fan toddler. :)
Having the cables on the back will have a insignificant effect on airflow. All it helps with cleanness of the appearance.
So I see ASUS has only dropped 3 of the registered Z890 Maximus boards. Can we expect the other 4 (Formula, Apex Encore, Dark Hero & Hero BTF), to drop before the Ultra 9 come out on Oct 24th?
I feel like Formula, Apex Encore or Dark Hero... would have better features than the Hero. And spending $1000 on the Extreme when it would be waaay overkill for my needs would be nuts.
I also have a new question, assuming those little blue sticker is the thermal pad, Asus has to assume that at some pt., we'll upgrade to some bigger M.2, or replace defective M.2, when that happen, the old blue sticker won't be usable, do we scratch off all those pad? they seem to be glue on the surface
Typically the thermal pad won't destroy itself just by removing a drive, its not that big of a deal. The blue sticker is protective film, btw. You pull that off before putting the drive in.
View: https://www.youtube.com/watch?v=ZcPhHV0WshM
so w/ this guy in his video, he just put the m.2 at m.2-1 slot, slide the square plastic, and close it.
first of all, thermal pad get soft by the heat. So the normal rule of thumb is to remove it and put new ones in.
but that's not the way we do it: are you saying the blue pad is the thermal pad? because they are not 22 mm wide? they are about 2/3 of that. Regardless, would there be any problem putting a 3rd party heatsink w/ good W/mK thermal pad on top & bottom to these new Asus m.2 slot?
I really don't understand at this point what you're confused about. Why are you looking at a $800 RAM overclocking board in the first place if M.2 thermal pads are confusing you.
I just want to make sure 3rd party heatsink can be used on their Z890 series motherboard, as I don't believe their stock heatsink can cut it. Further, you notice some manufacturer has their own embedded large heatsink that is bundled w/ their drive. So I hope Asus has to accept these m.2+stock heatsink on their m.2 slot
