I recently bought the NZXT Switch 810 white case and will be putting my system in that case sometime soon.
The case will be here tomorrow.
So far, What I plan to do is this:
Paint my DVD drives white to match the white of the case
Cover my fan controller in white vinyl film
Cover my AX1200 PSU in white vinyl film, Make a black stripe down the side and put these stickers on the side and top:
http://www.shadowmajik.com/Qstore/Qstore.cgi?CMD=011&PROD=1089973003&PNAME=Corsair+Vinyl+Decal
Either keep my current PSU cables or get a set of the corsair white psu cables (i dont want extensions)
For cooling:
XSPC Raystorm waterblock
Swiftech mcp655 pump w/ a koolance pump base - http://www.koolance.com/water-cooling/images/more/cov-rp450_p0.jpg
With a 80mm res tube and a 60 to 80mm adapter ring
XSPC RS240 radiator with push/pull Phoyba Red LED fans
Bitspower compression & 45 degree fittings
NO coolant, just distilled water and a killcoil inside the res
NZXT LED strip around the edges
Logisys UV sunlight stick
System will be:
Asus maximus iv extreme-z
core i7 2600k
asus matrix platinum
corsair red and black vengeance ram (16gigs)
lamptron fc8 fan controller
asus dvdr
pioneer bluray burner
Opinions welcomed
For cooling:
System will be:
core i7 2600k
asus dvdr
Opinions welcomed
