Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
you should try to run Prime 95 at priority 10 for 12+ hrs....if it fails before then, you need to up vcore or vdimm....if it fails, up vcore...if it locks your pc up, up vdimm.....running it at 10 will seriously slow your system down tho so don't take that for a lock up...here are some links:
