Up Processor
Berne
Hi All,
Do I have an option to upgrade my current Cel D 2.8ghz processor on my Gigabyte GA-8SIML board? Might save me a bundle for better FS9 performance with an upgrade to 2GB SDRAM?.....Just did some research and its yes I do have options, but its tech time...can you guys tell me if I would see a fairly good improvement in my FS9 performance if I made an upgrade from a 2.8ghz Celeron D (Prescott) to a 3.4ghz of the same spec...also I have the option to go further to a P4 Northwood 3.0 to 3.4ghz HT. Would the performance be much better on the FS9 with a boost in FSB from 533 ( currently ) to an FSB of 800 which is what Id get with the Northwood? Remember Im only interested gaining better performance for the FS9, not fast gaming or the like.
Berne
maybe if you went with the northwood 3.4ghz HT.. but is it really worth it for the insane amount of heat it creates? not really.. the cost to just upgrade the processor and ram on that system it would just be more cost effective to build a new system..
Hi,
Yes its looking very like a new build, the incoming figures show that clearly, thanks for the reply.
Berne
