Activate: AMD
- Nov 6, 2004
As the title says, I'll be up soon for an upgrade to my DINC. Its getting pretty long in the tooth and I'd like to upgrade to something with LTE. My problem right now is that most of the current crop of LTE phones seem to have crappy battery life. Theres also the fact that some new SOCs should hopefully be coming out soon-ish based on new processes and A15 cores, as well as LTE radios with lower power consumption. I'd like to avoid buying something now if a major generational leap is going to be made within a few months of my purchase. I could probably reinstall CM7 to fix some of the bugginess thats built up over the last few months (running a gingerbread sense rom right now) and gut it out if there was really a compelling reason to wait for something great.
Other than that, I can't say I'm in love with any of the offerings right now. GNex would probably be my go-to, but I could hold out hope that VZW will get a GS3 derivative, though it will likely have some typical crappy VZW modifications done to it.
Enough rambling though, anyone have any insight into whats coming up on the horizon within the next few months for VZW?
