Untitled Project (56k = NO)
Black Box
A while ago you remember that deal on that cheap lian li like case. I recieved mine a while ago and am currently putting my new watercooled system into it. Sorry for some of the blurry shots, my camera sucks.
The case itself is very conservative for now. I still need to get some leds, glowing power buttons, etc.
I bought a lian li side window for 10 bux off a friend. It fit decently with some modification.
Still a little bit of gap i need to take care of so it fits flush.
The inards so far.
I mounted the hd cage under my optical drive because it fit perfectly. It was originally mounted where the rad is.
Here is the hole I cut for the 120mm fan supplying air to the rad
Here is the 3 1/2 inch cage for the floppy drive. This will be where my water pump will be mounted out of sight.
The cage clears the wires from the optical drive perfectly.
Thats all I have so far. I will hopefully keep my thread updated. :D
nice so far, clean setup, well thought out, and well executed. I can appreciate that :)
Seems to be a popular case. I have one as well and love it. Want to install a water cooling setup as well. I'll be watching this one.
