farscapesg1
- Aug 4, 2004
Didn't know if this would be better here or under virtualization, but since the question is really related to hardware I thought I would take a chance.
I'm thinking about setting up an Untangle/PFSense VM on my ESXi box, which at the moment would be pretty straight forward. However, I also plan on adding another ESXi box and shared storage in the very near future for HA/Fault Tolerance and my question is how to configure this so the VM will run on either host...
Tell me if my thoughts are correct here...
Cable goes into cable modem, cable modem connects to a standard network switch (or possibly even a managed networks switch configured with a VLAN). Then connect 1 network port on each host to that switch and dedicate it to the VM as the incoming link. Another network port in the VM will be configured to connect to the network using the network ports assigned to VMs.
Should this work? Am I missing something? This is for home use, which should give me better options than my aging DLink 655 router.
