Untangle Build
Oldie
Mean Old Administrator
Curious what you guys think of this for a light duty Untangle Router:
I've already got RAM and storage. Looking for a cheapie build for a not for profit I'm part of. Will mostly be used for DHCP, VPN (max 2 concurrent users), and some basic content fltering.
The Gigabyte should do you just fine, and will be cheaper. Supermicro makes a very nice similar board with dual Intel I217's. It costs about twice as much, though. Depending on your connection it may not matter, but the Intels are generally preferred, and the SM should work with your RAM.
We've got a 100/100 connection so it's relatively beefy. Thank you for the replies!
