unstable vcore?
A8N Sli-deluxe on antec smartpower 500w
Everest shows the vcore at 1.30v, usually. It dips down to 1.26 and up to 1.33. This is my first time fiddling with a computer so Im not sure if I should be concerned or if this is normal, but I rather expected the vcore to stay rock solid...
CPU-Z shows a much more variable set of numbers, almost never on one number for more than a second. It goes from 1.264-1.328, usually between 1.296 & 1.312.
Is this something to worry about, is my motherboard or PSU crap, or is this within normal operating variances? Or are software readouts just not accurate?
It's normal for it to vary a bit and jump around. But that swing is a bit larger than I've seen normally. I usually see mine vary from .03 to .04 volts. So, from 1.49 to -1.52 or something like that.
But, well, if your computer remains stable, I wouldn't worry about it unless you'll be overclocking it. If you'll be overclocking it, I'd possibly be a little worried.
H
yeah i was planning to overclock now that ive got new ram. Should I look at returning my motherboard over this?
