Hi All,
Summary:
I installed a gtx275 and got some serious instability;
Frustrated with this problems I removed the gtx275 and replaced it with my time (and game) proven 8600gts... but the stability issues persist!
Aaaargh!!!
The rest of the story....
With the install of the gtx275 I was getting all of the issues listed above. To fix it I tried:
Through all of this, temps were well within norms: (degC idle-loaded)
So I eventually gave up on the gtx275 and have it packed up for RMA. But I'm still getting the crashes after plugging my 8600gts in. COD4 (which never used to crash) is now barely working at all.
So I've tried:
Strangely, the system hasn't crashed while running memtest for many many many hours. It seems that the system will only lock when I'm actually using it (if that makes any sense). ie - opening browser tabs, watching a video, loading a program, playing a game, wiggling mouse to wake up the monitor after being ilde for a while, etc.
This system has been stable for 2 years. The only changes were:
Note: I use many memory hungry apps; photoshop, lightwave, COD4, etc so I would have expected to have seen issues from bad memory a long time ago.
I'm starting to wonder if the gtx didn't bake my psu or something on my mobo; is this at all likely? Anyone know how I can test these components? And are there any really good stability tests for just the GPU or was furmark the right way to go?
System:
OS: Windows 7 64bit
CPU: Intel Q6600 G0
Cooler Tuniq Tower 120
Mobo: ASUS P5N32-E SLI (i680 chipset)
RAM: 4x2GB DDR2 Corsair (XMS2-6400, 4x2GB, 5-5-5-18)
PSU: Thermaltake 750W (750 AP- W0117)
Thanks, in advance, for any help/advice you can provide.
Cheers,
Dave.
Summary:
- intermittent locks
- spontaneous reboots
- BSOD: IRQL_NOT_LESS_OR_EQUAL
- System Event Viewer says "the nvidia display driver service has reported an invalid current state 32" (which google says is a bug in the 19x.xx drivers), etc.
- After reboot, onboard NIC wasn't detectable; warm boot fixed it
- chkdsk found errors on disk after one spontaneous reboot (not surprising if it was writing to disk when the system spontaneously rebooted)
Aaaargh!!!
- upgrading drivers to 191.07 (bad idea; buggy)
- downgrading drivers to 186.18 (uinstalled 191.07 first)
- underclocking using rivatuner
- stress testing with FurMark (4 hours, no crashes)
- open case to air + open windows to winter temps
- disabled windows 7 "background slide show"; this reduced frequency of crashes to about once per 30-120 mins.
- CPU: 37-47
- GPU: 45-84
- Mobo: 38-45
So I've tried:
- uninstalling rivatuner
- uninstalling nvidia drivers
- installing GPU drivers from windows update (system was stable with these prior to this whole fiasco)
- memtest - got two errors in 1018% coverate (whatever that means)
- pulling RAM pairs and running through memtest (no issues so far)
- Install W7 64bit 2mo ago
- Install 2x2GB RAM sticks2 mo ago (total of 8G)
- Disabling windows page file (so only RAM is used); 2 mo ago
System:
OS: Windows 7 64bit
CPU: Intel Q6600 G0
Cheers,
Dave.
