Unscrewing Motherboard Screws Hellp!
TicTac
I am trying to install a Scythe Ninja Plus, so I need to take my whole Asus A8N-SLI Deluxe.
However, I bought the computer all pre installed about 4months ago and the screws aren't budging. (the scresws that are keeping the mb down)
I've tried using a variety of screwdrivers, but I'm just buerring the screws away.
I note the bottom of the screws are sticking out the back of the case but can't work out what I could do. .
Could I moisten the screws? Or bang them from the back (but that might damage the mb)?
Any tips for removing vrey tight screws from motherboards?
THanks
heh i wonder if the guy that installed you MB used loctite... thats just a dick thing to do...
regardless, you should be able to back them out with a screw gun that has a hammer/clutch function, just get your harddrives and cd/rom out of the case befor you go at it (the hammering vibration will wreak havoc on the read/write heads of the drives) if that dosent work you may have to drill them out (or if there too striped) this one, you may not want to handle yourself, if you slip your fucked... if you do drill them out, keep in mind that the mobo standoffs will be ruined , so you might want to grab new ones befor you slice and dice ( and well as new screws... duh)
thore
/edit I'm in no way responsible for you wrecking your mobo if you decide to drill it out, if you use the wrong size drill bit, or if the earth cracks open and swallows you whole
thore said:
thore
LOL, don't worry, if the earth cracks open and swallows me i'll probably blame god :) they better not of used 'loctite', I don't sound very hopeful of being able to drill out these screws.. .
Anybody else thnk that is a bit off? What case do you have? OR arew you talking when you take the other opposite side of the case off?
Yer sorry I worded it wrong, I meant after I take the opposite side of the case off, the screws are obviously coming out the other side.
You sure that is the screws or is it just the studs? Might be able to clip off the ends of the screws/studs take a hole punch, and try to punch it the rest of the way though. Just a thought though.
_lefty
A #2 Phillips Screwdriver is what you should be useing, a #1 has a steeper angle on the point and will not grab the screws well. If you cant get the screws out that way, I would be very scared to try anything else, even if they did use loctite they should still come out with just a screw driver and a good grip!
You may also try useing a Ratchet and Socket, that is if they used the screws with the Hex heads.
If there is loc-tite on the mobo screws/standoffs, just take off the backpanel of your case, and you should see where the mobo standoffs are screwed in. They should barely stick out the back a hair depending on how thick your mobo tray is. What you want to do is just take a torch and heat up where each standoff is for a couple seconds to get the loc-tite to melt. Thats all you need is a little heat to loosen it up. A cigarette lighter might even work. It won't damage the board since it is around front of the tray. Just don't hold the heat on it for more than 30 sec so it gets glowing hot.. lol. Once it gets hot, quickly go around front and loosen up the screw. If your talented, you can hold the heat on the backside, and unscrew from the frontside at the same time so you know exactly how long it takes for the loc-tite to melt and you don't have to use excess heat.
Oh screw this I'm screwed :mad: :p
The screws are all mucked up now, I might have to sell the motherboard in the case, and buy another one.
i would take it to the place that you bought it and say, you try you made this dang thing. Than make them replace it ;)
or try some craftsmen damaged screw removers, they work nice
Are they just spinning when your turning it? just get a wrech or pliers and grip the backside of motherboard stand off and unscrew the screws.
if they are hex head screws, and most are, use a 1/4" nut driver. they may have been screwsd in with some kind of power tool that was over torqued. you will get better leverage with the nut driver. or like the above guy says, you can get a set of bits from sears that are specifically made for removing messed up screws. a great, useful tool. for around $15 iirc.
My #1 mobo install commandment: NEVER EVER use a power tool to install the mobo standoffs and/or the mounting screws. I've seen some 1d10t's use a cordless screwdriver to install the brass standoffs and the mounting screws, they were in so tight, you had to use a power tool to remove them. Stupid stupid stupid.
No no no, they won't budge at all.
Thanks for the advice people, I will see if there is anything i can do
