Unrecognized USB/Firewire Card in XP
montezuma
Hi, I have the SYBA PCI USB 2.0 & FireWire/1394a combo card Model SD-COMBO-02 found here. When I originally installed it, I was running Vista, and it worked. I've since gone back to XP, but it's only showing up as an unrecognized PCI device, with none of the ports working. Checking the drivers, I found vendor ID 0106 and device ID 3044. PCIdatabase shows two firewire devices with that device ID, but no vendors with that ID. One of the devices is a VIA, which is vendor ID 1106, so I thought maybe the device was given the wrong ID. I don't know if it's even possible to force that, and this device isn't even supposed to have a driver (I couldn't even find one anyway). So is there something I can do here?
After installing both drivers and rebooting, the device now appears as an IEEE 1394 controller, but it still isn't installed.
There is another unrecognized device, showing as a Standard Enhanced PCI to USB Host Controller, with device ID 3104, and the same vendor, 0106. I really think this problem could be solved if there was any way to force that vendor ID to change. PCIdatabase shows this as a VIA USB 2.0 Enhanced Host Controller.
The ALI and VIA drivers since I don't know which I have. Trying to manually install them in device manager brings up the "cannot find driver" window, whether I try it through the 1394 controller or the PCI to USB controller.
First, figure out which one you have, and go from there. If you have the VIA one, there are other drivers on the VIA site, linked off of that syba page.
I've tried other drivers in the past, and I haven't yet got one that it'll accept. I'm almost certain it's related to that incorrect vendor ID. I tried changing it in the INF file of those drivers as well, to no avail.
What about the drivers on the disc that came with the card?
I've never had to change the vendor ID of a particular device just to get it to work. IRQ's and other stuff, yes, but not the Vendor ID. Any IRQ conflicts?
The driver disc is what I tried first. As for IRQ, I see that there are separate entries at certain IRQs, but it isn't reporting any conflicts.
