Unplanned upgrade..a few questions
Darkstar850
So it appears that my motherboard toasted itself, so I am now looking to upgrade a little ahead of time. I was hoping to wait about 6 months to upgrade, but I don't want to buy a new motherboard for an old crappy system. Just replacing the core of the system, will use old parts for the rest for now.
So far, this is what im going to go with.
Athlon XP 2400 mobile
Abit NF7-S
I want to overclock a little, nothing major. Seems like people are getting FSB up to at least 200, that will probably be my goal.
Parts I am still looking for
RAM - Prefer 1 stick of 512 right now, will add more later. Don't want to spend a ton, but I will spend what I need to. Want to be able to hit 200 FSB if the proc will do it.
Was looking at this:
http://www.newegg.com/app/viewProductDesc.asp?description=20-145-026&depa=0
Will this cut it?
Also looking for a new case, since the cooling on my current case is crap. Would prefer something with 2 120MM fans. Would like a fan in the side also. I would prefer not to have a side window, but if a case with one meets the specs, I'd take it. I have found some cases with 120MM fans, but none with a fan in the side. Any ideas?
proc looks fine..
for the motherboard i suggest going with the DFI ultra infinity. the best oc'r out there.. you may just be able to take your OC higher... why not? its free.
as for ram id suggest going with muskin's 2-2-2 special, its bh-6.. while obviously its not bh-5, is still pretty good.
or go cheaper and get muskins level one. which runs at 2-3-2.
Will it really be worth the almost 40 dollar difference for level 1, or the 70 dollar difference for 2-2-2 special? I am not planning to push it that hard. I basically just want to run the ram at stock speed.
For Athlons, timings are important and help with performance if you have lower timings. However, if you don't give a squat, I'd say the Crucial would be fine, otherwise, I'd go for the Level I. The Special 2-2-2 is preferred, since it has the tightest timings, but it's up to you and your wallet.
Just remember to never use asynchronous modes on Athlons.
Just buy the Mushkin PC3200 lvl 1 with CH-5 chips. They will run 2-3-2-5 which would be completely undistinguishable from 2-2-2-5. The BH-6 chips aren't nearly as overclockable as the BH-5 chips of old were.
Its definitely worth it to get quality Mushkin, Corsair, or Kingston that can run at least 2-3-2-5 though. I just bought 1GB of Mushkin PC3200 lvl 1 for my P4 rig.
The only way i can get 512 MB sticks of lvl 1 ram is a 1 GB twin-pack. This runs about 210 bucks, which is a little more than I am willing to pay right now. I may look around to see if I can find a single stick somewhere else than newegg.
Seattle.
If I can get away with it, I would rather not buy 1 gig of ram right now. I am so busy I don't have time to play games or anything very stressful to my system. I just need a machine back up and running for now. If I could get a single stick of the mushkin L1 I would probably do it, it should only be about a 20 dollar difference.
He has an Athlon, the most he'd every need would be PC3200 for overclocking. I don't think he'd be ramping that FSB past 200 Mhz from 133.
Hmm, and that will let met get 1 512 stick for now. That may be the ticket right there, although its quite a bit more than I was hoping to spend. I guess it will pay off in the long run, since I tend to keep my machines for quite a while (see sig)
