Unmountable Boot volume
CaptainMorgan
[H]ollywood
Freaking Winblows.
Running 7 64bit, and this error comes up, all you get is a black screen with a cursor. No ctrl alt del or anything works.
When I put in the repair cd, it simply loads the files and goes right back to the black screen with cursor!
I need some help, there are important files on this computer (dads).
Safe mode with CMD prompt doesnt work either, just blue screens. Any other way to run CHKDSK I dont know about?
Boot off the Windows 7 DVD. When you get to the second screen there'll be an option at the bottom for Repair functionality, choose it. When the next screen loads it'll search for your current Windows 7 installation and it should find it; if it doesn't you've got bigger fish to fry.
If it does, click Next to get the actual options. At the bottom of that dialogue is the Command Prompt option, choose it.
When the Command Prompt appears, type the following 3 commands in order; as long as the first 2 say successfully completed, you should be good for the 3rd command.
bootrec /fixmbr (then press Enter, wait for the status)
if ok then do:
bootrec /fixboot (then press Enter, wait for the status)
if ok then do:
reboot (then press Enter)
and pull the DVD from the drive when the machine reboots. That should get you functional again IF the tools were able to find the installation in the first place. If not then it gets a lot more complicated but, give that a go for now and report back.
Good luck...
Thanks Bah, but sadly it doesnt get that far, just white loading bar then back to the black screen :(
Ouch... hrmmm... not much I can think of past that point. :(
If it was mine I'd do the manufacturer's diagnostic on the hard drive, if that turned up negative I'd yank the drive and start backing it up with another machine (assuming you have one handy), and then get ready for a clean install. Some people say I'm lazy in that respect with my "clean install" recommendations but, after decades of working on computers, I just don't give a fuck anymore... :)
When it's busted, I'm looking for the fastest most highly efficient way to get it fully operational again, in my experience that means back it up, start over. Just how I get things done now, I suppose. After all the years I've put in, it's the easiest simplest most efficient method when things go wrong. Sometimes you get lucky and it's an easy fix if you decide to go the hands-on troubleshooting route, but far far more often it just becomes a waste of valuable time (especially if you're not getting paid for this kind of work, most notably on your own hardware as this case is I think) and you end up doing the clean install anyway... :(
I hope it gets resolved, however, regardless of the path you choose.
When I did run the diagnostic, it said the drive was not found?
If I swapped the drive into my laptop, it wouldnt screw up the data on either drives would it?
It shouldn't, no, but the fact that the manufacturer's diagnostic can't see it could either be because a) the diagnostic doesn't have a driver compatible with the controller (SATA issues usually) or b) that drive truly is toast. :(
Yank it out and attach it to another machine and hope it gets "seen" and you can do something with it.
