That's a good thing....that means it's finding problems, and most likely fixing them.freeikon said:does chkdsk usually take such a long time? I mean it got to 77% then went back to 50% and its up to 65% now.
Creates an image of your hard drive on another computer or on CDs/DVDs. It's meant to backup a full system, or clone one computer to another. The method in which it would work for you, is that you'd ghost your entire hard drive to an image file on another machine, and open that image file like a giant zip file, extracting any data files you needed.freeikon said:What does this Norton Ghost do?
He posted above that it's all been tried, to no avail.microcosm13 said:Before wiping i'd advise putting in your XP disc, boot up, and follow the steps to do a normal install.
When it gets to screen 3 or so, the one with partition info, has a box at the bottom with your partitions in them, instead of doing an clean install there should be a repair option. Press that key, i think its R. And windoze will rewrite all ness files, and hopefully get you booting.
freeikon said:Nice, I'm gonna get that. Thanks for all your help, I know that formatting and the likes will work, so I'm just gonna get down and do it. I'll do like you said first so I can save some files, otherwise just gonna do a clean install. Start from scratch again
