Unlimited Detail Graphics Technology
Ya, what you have to remember with just about anything computer related, especially graphics, is that the theory part isn't the hard part. We don't need to figure out how to do something to make graphics more realistic, that's already been done. The hard part is making it work on silicon for a price people can afford.
As noted, Voxels are nothing new. It isn't some amazing new theory that would let us change how graphics are done. The trick would be making hardware that could do Voxels at a high speed that gives better results than our current rasterizers.
Don't believe hype from a company until they can show their stuff running on actual silicon. There's been plenty of people in the history of computers who have shown an amazing new technology and then never been able to make it actually work in the real world.
The Elbrus E2000 was a good example. Elbrus is a Russian company that has made supercomputers. So the E2000 was to be a supercomputer on a chip, something vastly in excess of the speed of anything out in the day. Well obviously it never came out. Why? Because they designed something they couldn't build. They made a neat looking chip in VHDL based on what they knew about supercomptuers and more or less said "Now we just have to fab it, which is the easy part right?" Well as Intel will tell you that's not the case, making a design you can actually fab and release is the real trick.
Until a company shows you their amazing new trick is doable on real silicon, maintain a healthy dose of skepticism.
I would agree generally...but isnt what Unlimited Detail doing a little more technical and "prettier" than regular voxels? Or is what theyre doing still voxels...but just higher resolution voxels? Also, how are they doing reflective water and shadows? Are those just basic 3D (i.e. DirectX) objects running on top of the voxels?
The video suggests that they are doing shadows by simply having two of whatever object - one for the object itself, and one flipped for its shadow. I assume reflections are going to be the same.
But the don't address the real problem with voxels - which is that you can't animate them or make them dynamic, it is simply way too slow.
Pro tip: never invest in a company that uses the words "But I assure you, it's real and it all works."
If what you say is true, couldn't we merge voxels with what we're already using? I mean, not everything has to be dynamic. Look at the dragon and stuff in the Heaven demo for instance; that one's using Tesselation to add the detail. What if we used voxels for that kind of things? I.e. for the basics of the game world, and not things that would need animation.
Yup, that is actually what some games already do. The terrain in Crysis was rendered using voxels, for instance, and Carmack has already talked about more heavily mixing voxels with polygons in up coming id tech engines.
So, basically, they claim to have found a new algorithm to determine the nearest intersection (or should we say, approximation) of eye rays and geometry based on high-density voxel maps. Furthermore, they implicitly specify this new algorithm to be of O(1) - or O(n), if we would like to be nice - complexity by calling their technology "Unlimited Detail" and being able to process "billions of points" and "run it all in real-time".
Even though I think that using such high fidelty voxel geometry (or points clouds or whatever you would like to call it) in realtime graphics processing is quite possible nowadays, such technology has many significant drawbacks:
  1. The amount of memory required to store such geometry is not in the least acceptable for general purpose graphics. Imagine the billions of points to be stored. Just for a few scenes you would require many TBs of storage, not to mention the GBs of RAM you'd need to actually process all that.
  2. Dynamic scenes are practically impossible to simulate using this approach. You could define a subset of a voxel cloud to be a separate object and transform that as a whole though. But what about special effects? I don't think vertex and fragment shaders are capable of dealing with this approach.
  3. Current Direct3D 11 class hardware offers tesselation which renders one of the primary arguments for this approach - traditional rasterization doesn't offer high-detail, curvy geometry - kind of invalid.
As a developer, I can see some applications in which the use of voxels seems the ideal solution such as advanced raytracing which brings together triangle-based geometry, procedural and mathematical surfaces and voxel maps. But for realtime graphics and in such an extensive way? It seems highly unlikely to me... :rolleyes:
Listen to this person :)
Voxels are good for some thing for example it allows terrain that can have complicated caves and overhang that's not normally possible with a basic heightmap models. But as someone else said dynamic environments and animated models are not possible (AFAIK) so it renders the technology useless for a lot of things.
That's something that people who have pet technologies are good at: Forgetting real performance limits. You see it with Raytracing all the time. "Rasterization is O(n) Raytracing is O(log n) Raytracing is better!" Clearly someone who's just taken some CS classes, or who's got a tech to push without thinking about it. In the case of Raytracing, one of the problems you run in to is that it requires lots and lots and lots of memory access back and forth. When you are doing big O and calculating theoretical speeds, that's fine since your memory bandwidth isn't factored in and thus is infinite.
However we don't get to have that in the real world. In the real world, memory bandwidth is limited, usually way more than we'd like. So you discover that it becomes a problem rather quickly. High detail scenes don't scale logarithmically not because of processing, but because of memory. You are getting held up at all the back and forth of data you are doing.
Same kind of thing you'll likely find here. There are real factors that limit the usefulness. As I (and others) have said, it isn't as though we don't have better algorithms for more realistic graphics. It is that they can't be implemented on silicon at a high speed. Another good example in terms of geometry is NURBS. Those are how many professional 3D packages handle elementary design. They are really slick in that you can define complex curved surfaces of high detail with just a few control points. Brilliant! We'll use them everywhere...
Except that they take massive amounts of processing power to deal with and render. While you can design beautiful scenes with them, that are extremely high detail and have no hard edges (as you see in major Hollywood CGI films) you can't then take that scene data and quickly render it to a screen as we need in games.
Thus we use polygons and rasterization with various tricks. This isn't because the companies don't know how to do anything else, it is because it is what we can make work on real silicon that can be sold to consumers.
I think people often forget you still have to generate 245,760,000 pixels in a single second to get 60fps at 2560x1600.
