Unknow Device In Hardware Manager...
USMC2Hard4U
I cant for the life of me seem to figure out what this is...
Will post screenies in a few if a solution isnt found but...
I have installed Everything in my PC... everything is good except for this one "Unknown Device"
Location: On Intel (R) 82801GB/GR (ICH7 Family) LPC interface controller 27B8
its something with the ide/sata or pci controller I think. did you ever install those drivers?
Edit: have you downloaded and installed the latest chipset drivers
Did you ever resolve this? I just bought a, Intel 975BX mobo and have the same problem. I've downloaded all the latest drivers and still have it. :confused:
Edit: The fix for me was to manually install the driver. I manually selected the hardware from a list and it worked. No idea why I had to do it this way, but figured I'd post it in case someone else has this problem and searches for it.
I did, it was a USB port that had nothing plugged into it. As soon as I pluged in a device to it, the computer found the USB port, then the device...
