Universal Memory Device Touted as DRAM/SSD Replacement
sknight
Scientists working at Lancaster University in the UK have secured a US patent for a new electronic memory device which "could solve the digital technology energy crisis," reports Science Daily. The 'Universal Memory' device is said to combine the advantages of both DRAM and flash memory with none of the drawbacks that usually come with such compromise. Furthermore, if the new memory format were to be adopted by data centres it could reduce power consumption by a fifth, it is claimed.
Click https://hexus.net/tech/news/ram/131993-universal-memory-device-touted-dramssd-replacement/ for the full article. Be prepared, not a ton of depth yet, but an interesting concept.
Silver
"the contradictory requirements of non-volatility and low-voltage switching, are achieved by exploiting the quantum-mechanical properties of an asymmetric triple resonant-tunnelling barrier."
well said
There are many simple solutions to complex industrial needs. Hell, my farts contain enough energy to recharge my cell phone several times a day. This power source is plentiful, readily available, and spontaneously abundant, although it is not non-volatile.
However, I am not allowing any quantum-mechanical exploitation of my symmetric double resonant-tunneling barrier.
P.S. Where does the term 'intestinal fortitude' come from, and why are we serious when we say it?
Intel Optane was recently released to the market and has the same features:
DDR form factor - socket compatible. (Support already built into windows/linux/ESXi for Optane memory)
non-volatile, retains the data when powered off
access times of 300ns. typical ddr access times are about 50ns, ssd's ~100ns, hardrives ~ 10,000,000ns
very dense. comes in 128Gb sticks and 512Gb sticks
can double as HDD storage, and be re-partitioned back and forth as both System RAM <-> HDD. This was a touted feature in a talk I attended at VMworld.
...probably super expensive, at least at those huge sizes.
Comes as m.2 form factor as well, under $100 but the biggest is 32Gb? Appears to be meant to be used as a smart-boost or whatever windows tries to do with thumbdrives to bump performance... a cache device. Looks like for that purpose it works well.
If your 'intestinal fortitude' fails your intestines rupture or spontaneously combust (Bust into flames)... >_>
Hmm. This makes me think about what happened to the competitors for Xpoint. There were a few different technologies that were discussed over the last 5+ years that did not seem to become products yet.
Sure, just like the HP's Memristor was supposed to revolutionize storage. It's all just a bunch of companies coming up with half baked hypothetical ideas so they can patent it and then wait for someone else to actually do the work. Storage will be revolutionized when someone can get rich off the licensing, otherwise we just maintain cruising altitude.
well said
Damn right
I came up for air right before the description of how the captive hole is nondestrucitvly 'read'.
Working in hardware, impressive!
