Uninterruptible Power Supply For Server
YellowSnow
My current UPS just died and I'd like to replace it. I've calculated that a 1500 Watt or better unit should do the trick. I plug some networking devices into it as well. Battery life at full load only needs to be 15 minutes or so, but the more the better. Dependability is the most important factor.
Budget is flexible, but value is important.
Oh, and I'd like to be able to configure it to gracefully shut down the 2003 Server and I know most UPS manufacturers charge for the server compatible software to do this, so please take that into consideration. Do any UPS brands offer free monitoring software for servers?
Thanks for any advice.
Cyberpower
Thanks, I did notice that their included sofware is compatible with Server 03 and 08.
Would I notice much of a benefit by buying this over this?
Seems like the more expensive one just has the benefit of "high-performance Pure Sinewave technology" and an extra 100w of capacity.
what type of server?
I'm a dell server guy, so anything like a Dell T310 and under i use that 1500VA unit, bigger I go with the 2200va unit not pictured
It's an HP tower server. Proliant ML350 G6. I actually wanted a PowerEdge T410 but it had too long of a lead time and it had to be received before the end of the year...
yes should be sufficient, I have one of those on a PowerEdge 2900 just used till hte generator kicks on.
Just wanted to show the other one I used.
