Or just use revo uninstaller and run the advanced uninstall. The best part is, even if the uninstaller is broken and fails, revo will continue it's part and find all registry entries, files and folders, then delete them.Last resort... Delete the files manually, go in regedit, delete the uninstall data, remove it from start menu, and use msconfig/hijack program to delete it from starting up.
