ninethreeeleven
TKer
- Jul 16, 2004
Okay what do all of you guys recommend for uninstalling a program. Please clarify your answer if you find there should be more than the above choices.
riot8ap said:I go the program files directory and delete the folder...i then goto the windows system directory and delete .dll's that sound like they might come along with the program.
displays the entries in the Add/Remove Programs list of Windows Registry, checks if each is valid, and uninstalls the selected program or removes the entry from the list. < Official description
Maybe no one is like me, but you should see my Windows Add/Remove Programs list. It is full of
broken links. The only way to remove them is to open up the Registry and try to figure out where the
Uninstall entries are. I'm too lazy to do this more than once a year, so I wrote Add/Remove Pro.
Just run Add/Remove Pro and it will show you which links are bad. Press the Remove Entry button to
remove the entry. If you would like to uninstall a program, press the Uninstall Program button.
- Ray Geide, author of Add/Remove Pro
