unifi controller question
unwantedSN
Im pretty sure the answer is no, but...
Is it possible for the controller to tell me how much data an IP or hostname has used on a given day/date?
You can see a total that each device has used. Its not really detailed in the UI as far as exact times by device, etc. More of a total.
I believe you can pull more detail from the logs though if you do some parsing.
You can get a little more detail if you click on the hostname/MAC address of the client, but this is about it:
If you need really detailed stats you would probably have to do something at the firewall level.
